- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Thank you.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@carlyn_05 wrote:
Encountered the same problem when I chose mp3 as ringtone, appeared as unknown. Then I tried once more changing the phone ringtone thru sound picker then clicked the music icon on the topmost right corner that lead to sounds where I was able to choose the mp3 as ringtone and it was already recognized showing its title.
I agree with carlyn_05, before i saw this post i found the solution on youtube showing how to do it on the Z2.
Setting > Call or Sound (Its the same anyway) > Phone ringtone > Choose Sound picker > Look to the top right corner on your phone and press the music note icon > Scroll down to where your music is > Your music will now be in your Z3 default ringtone list. This also works the same for Notification sound setting.
(Note: The MP3 ringtone will not be save permanently like most phone after you set, when you change to another ringtone the previous one will be remove from the Phone ringtone list.)
I can say there are many like me who would feel the same about just wanting our Z3 to set the ringtone and not want to reset or use any App to fix the problem.
This post was made on 23-Dec-2014 6:31PM (UTC+08:00)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok this is how to change ringtone of your choice on sony zperia z3 compact connect phone to computer go to start on your desktop and then my computer you will see your phone icon click on it and if you have sd card installed you will see internal memory and external memory click on internal memory you will see folders open the folder named ringtones please note that ringtones are wav files not mp3 format so you will need to convert your file before ypu start i recomend audacity for this however once you have done this drag the wav file from you desktop into the ringtones folder then click back and you will see a notifications floder click on this and drag the same file again from your desktop into it then close the window on your phone go to settings / sound and notifications / ringtones and you will see a list of tones including the one you just added click on it click done and your now finished
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My problem is I can't assign a ringtone to a contact. It doesn't save. All ringtones are the one I chose as the default - an mp3.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it only works for me if i move the mp3 file from the sd card to the internal storage. never had a problem with my previous M4 (only with the M5). is this a thing? you can only set a mp3 ringtone if its on your phone internal storage? or im missing something?
would love the help.
thanks
- « Previous
- 1
- 2
- Next »
