Storage space issue Sony Xperia Z3
DanielMKing221
I keep getting messages saying that I am running out of storage space. Why?
The Cache has been cleaned. It says I only have 500mb of free space, but only says there are approx 4gb of data installed. Does any one know why this has happened and is there a solution. Thanks.
16 REPLIES 16
Uliwooly
Could you upload the picture to box or Dropbox and post the link here
stockyvillage
Looking at the graph you should have roughly 9GB left.How much data is in the misc folder?
Uliwooly
There's something going on with your phone perhaps if you boot on safe mode
Phy
Legend
Legend
Olgapall
Prompt how to transfer appendices to sd the card? I removed already almost everything unnecessary ((and the place all the same isn't present.
Phy
Legend
Legend
Try repairing your phone with Sony PC Companion .
http://support.sonymobile.com/us/tools/pc-companion/
eskah78
Got the same problem storage slowly filing up for no reason cache empty uninstalled almost every app i should avec 6gb free yet im full. Original non modified setup a 128gb sd (no problem on the sd only on main storage)
profile.country.de_DE.title
bilomar
Did anyone solve this problem? I have the same issue on lollipop. Do I really have to reinstall firmware to fix this?
stockyvillage
@bilomar can you put a screenshot up .Also do you take a lot of photographs and just delete them off device.As they just go into the bin so still take space up in apps until you empty bin
