Solved! Go to Solution.
Actually I'm unsure of the material but I just tested here and I don't think you need to worry about breaking the 'strap hole'.
Strap hole is made by drilling hole in to XZU aluminium alloy frame so dont worry you might break you mobile or strap not strap home..:P
