The best region?
imanolu
The best region?
which would be for you the best version for xperia z5?
1. Customized NOBA
2. Customized DE
3. Cuztomized IT
4. Customized ES
7 REPLIES 7
profile.country.US.title
Qatrium
@imanolu
There should be no major difference, apart from extra "bloatware" added on specific markets. But all basic coding and Android features will be exactly the same.
imanolu
and updates do not work out before going in customized NOBA?, many people have that version
Uliwooly
@imanolu
That will be USA USA USA jk, go with the global generic or nordic version.
imanolu
I can not install the USA version since networks in Europe are different
totoroo
It might be that you can, actually.
You have the option to flash selectively, ie, don't flash the baseband file.
I have never tried the us fw myself but flashed several european or my original canadian one with same results and at least same lte bands (you can compare yourself the bands available in the service menu
Uliwooly
@totoroo @imanolu
I've done this with other Xperias, as long as you exclude the baseband it should work.
profile.country.NL.title
Strampke
As far as I have understood updates land faste on DE than on NOBA.
I will try to find out today by switching from NOBA to DE
