The touch screen does not work correctly
Alena3561
The bottom buttons constantly work when I just click something or flip through it. The transition to the factory settings did not give anything. Sony z3 compact.
Tags (1)
5 REPLIES 5
Uliwooly
@Alena356
Settings > about phone > diagnostics > test > test touchscreen
if your phone has a protective case, film and/or glass, remove them then test the screen.
Alena3561
I do not have a protective film or glass.When I place the phone in the cold, for a while the screen works fine, then again starts to buggy
Uliwooly
@Alena356
did you tested the touchscreen?
Alena3561
Yes, the diagnosis does not give anything
Uliwooly
@Alena356
You probably have to get it inspected by your Local support
