Hi. How I can change touch screen sensitive on my Sony Z Ultra?
Hi @Oleckowsky10, welcome to our community!
There are no settings that will change the screen sensitivity. Are you experiencing any unexpected behaviour with the touch screen?
If you are and you have a screen protector on the device, try removing it as this can impact how the touch screen reacts in a negative way.
Let me know a bit more about the behaviour and I'll do my best to assist you!
I just changed the LCD with touch screen and touch screen responding when I pressing screen a bit harder then I should... I think. Responding all the time any time at any places, but not that soft like should.
That's how It's possible change on Z2...
Hi again!
Did you change the touch screen yourself, or was it done at an authorized service centre? If it was done at an authorized service centre, I would recommend that you get in touch with them directly and let them know about this.
Regarding how to change this on the Xperia Z2, that most likely involves some modification of system files and that is not something that I can provide any support for.
