Turning of
Bigelly
Turning of
Hi I have a z5 and I got a new battery put in it last night and now it decides to turn of when I'm using it and I have to put it on the charger to get it to turn back on and when it comes on the time and dates are wrong any help would be greatly appreciated
4 REPLIES 4
Uliwooly
@Bigelly
If you got it replaced by Sony or someone else, you sould contact them.
If you DIY then, check that all the ribbons are properly connected.
Bigelly
I got a man who is really good at handsets to do it and this is the first time I've had any bother after he's worked on my fone could it be a faulty battery?
Uliwooly
@Bigelly
your guess it's as good as ours
Bigelly
I have also discovered the screen is dull then it brightens up every 2-3 mind
