Goodmorning,
I have a Sony Xperia Compact Z3. Some days ago, I did something wrong settings I guess. Now, I can't access some Apps anymore, like Photoalbum, Musiclibrary and Cleanmaster. I get the note "Allow Album to access photo, media and files on your device" (same note for the other apps). If I select "Allow", then it says "Screen overlay detected". To change permission setting, you first have to turn off the screenoverlay from Settings > Apps. When I "Open Settings", I get to the screen "Draw over other apps". From that point, I don't know what to do. All the apps that shows "Yes"". On the right, you can select "Show system or Reset app preferences"".
Could you help me from that point?
Thanks in advance
