my phone vibrating not work
i already test with diagnostics tool & use reset factory on my phone
still my phone can't vibrate
anyone have a solution ? :'(
Thx n i can't speak english properly, sorry
hope u can understand my mean
Solved! Go to Solution.
I've tryed to contact the Sony Support, but they doesnt reply
They will,after weekend.
Now it finally works!
Thank you very much for the Support! You are a great help! :smileysmileythumbsup:
How did you fix it?
Hi, I've got the same problem. Can you tell us how did you solve the issue. I'd rather prefer not to send it back to sony.
Thank you
I did what you said. Open the Sony PC Companion - Click 'Support zone' - Update phone/tablet softwere - then click 'repair my phone/tablet' - then just follow the steps.
But it took me about 3 hours to complete the update, so make sure you have time enaugh.
Otherwise its because i have slow internet 😛
So the repair helped.Awesome.
Hello there a Year Later. I just tried all the suggestions you all had and my vibrate still doesn't work is there no other way of solving this issue without sending it to Sony? Im desperate:smileyworried:
