In the last android version (7.0) you can't control them well like before, you should open settings to choose volume type.. HOW CAN I FIX IT??
@Murad96 I think you may want to perform a software repair using Xperia Companion because the volume can be changed in the same ways as of Android 6 Marshmallow...
a) If you are not listening at any media, volume buttons change the notification/ringtone volume;
b) If you are listening at any kind of media, volume buttons change the media volume;
Hi @Murad96, welcome to our community!
Could you elaborate a bit on what kind of behaviour you are experiencing with the volume controls?
Just like @YoGem pointed out, when you use the volume up / volume down button when you aren't listening to music / playing a video and so forth you will increase/decrease the volume for both ring tone and notification sounds and while playing media you will increase/decrease the volume for the media being played.
You can also access the menu for all 3 of types of volumes if you press the small arrow to the right of the volume control that appears when you press on the volume up / volume down button.
Let us know a bit more about this and we'll do our best to assist you!
