Walkman bug on Android 4.3
Derik
Walkman skips songs.
For example, if I am listening to song #1 and want to listen to song #2, Walkman will skip to song #3 instead.
Anyone experiencing this or have a solution?
Derik
It is not a deleted song. I can play the song if I press the skip button a bunch of times.
I have cleared the data but there is no change. Restarting the phone does solve the problem. I'll see if this solves the issue permanently
Thanks for the advice!
6 REPLIES 6
profile.country.RO.title
_alexdon_
Is the song nr 2 on your phone or is it a deleted song?Try to clear data for walkman(settings-apps-all where you find 2 apps).Restart the phone.
alexdon
Derik
_alexdon_
You are welcome.You can consider force restart sometimes(power button+vol up until the phone vibrates).You may encounter better results.
alexdon
Derik
I will keep that in mind. Thanks again!
Derik
Walkmn problem still persists. The hard reset solves the problem for about a day only.
_alexdon_
It is a buggy software then,nothing you can do.Only install a previous version of walkman,but you have to root your phone.
alexdon
