Hello All.
The Walkman app is a nice player.
But...how can i configure it that it only shows local files on my sdcard1 ?
I don't want to use network streaming, i just want to listen to my local stored (huge) collection flac files.
Is disabling 'music unlimited' all i need to do? (i use a €3,- for 3 months action from playstation4)
Solved! Go to Solution.
Just turn off music unlimited, walkman will play the music stored on your SD card and internal memory
Thanks for the fast reply.
Cool, it saves my mobile data bundle when i'm on the bike. (out of wifi range)
I was a bit confused about artists i don't know, but those are the demo songs, i'll remove them using AndExplorer.
Any file manager will work
OI file manager, root explorer, etc
