Where is the clipboard?
Singleberry
I want to change my font,i downloaded an app found the font i like and copied it to my clipboard...where is my clipboard? How do u find this in my xperia z3 compact? Grrrr
CameronT
Champion
Hi @Singleberry, welcome to the community.
The clipboard is a place to store text and images you have copied temporarily. You will not be able to install a font using it.
In most cases, you can not install a font without rooting your phone. Some third party launchers include font options though, so if you are wanting a font without roothing your phone, look on the Google Play Store for Launchers.
