Xperia Smart Call Handling
Kurapiko
Hi I'm Xperia.Z5 Compact User now I think I'd tell you about Smart Call Feature Sometime It's such of slow it could not be detected my ear but It would be detect after that 3 times repeat ,So It's really not stable and inconvenient feature since Z3C Please fix it
Thank you
8 REPLIES 8
profile.country.RO.title
_alexdon_
@Kurapiko Can you try to answer some calls in safe mode? It works ok on my Z5 and Z2.
alexdon
Kurapiko
How can I access Safe mode? please tell me more
_alexdon_
I have left you a link in my first post. Press longer on power button, a menu should show up. Then tap longer on turn off, you will be prompted you restart in safe mode.
alexdon
Kurapiko
What is the advantage of using this mode?
_alexdon_
Basically, 3rd party applications (those installed by you from google play or other sources) are disabled. Sometimes, these apps can interfere with your phone's functions or features, making them not to work as intended.
alexdon
Kurapiko
OK I'll try testing this at the moment
Kurapiko
How do I access safe mode?
profile.country.US.title
Qatrium
@Kurapiko
Use this link for a guide: safe mode.
