I tried to install Timeshift Burst app from the Google play. The app downloads just fine but it fails installing it to my Xperia Z (6602) 4.3 giving "could not install error -24".
Can any one help me on this? My phone is not rooted.
Check the attached screenshot.
Solved! Go to Solution.
Found a solution Just back everything up using backup data. And factory reset the phone. And then first thing you should do is download the Timeshift burst. It worked for me.
same hea
