My phone was out of battery, and I pluged it into my PC(with a cable) but the thing is the connection went off somehow and now there is only red led light.... I tried to re-plug in 2 different PCs No response from each PC,
I tried to hard reset the phone(no response to it too)
Even PC Companion can't see the phone...
Is there anything I can do besides waiting for battery to drain out?
Or is there any way to drain battery out?
Solved! Go to Solution.
You need to connect the phone to wall charger,charge for 2 hours,force restart the phone(power button+vol up until the phone vibrates).
I'll let you know if it works
Sure,take your time.
Yep It worked Thank youuu sooo much
You are welcome.
