Hello,
before 3 days I let my phone get to 0% (I know, stupid) and the I plugged it in
It was plugged in for 8 hours overnight, yet it is not turning on this morning
I tried a different charge for 2-3 hours, still no result.
The LED light flashes red three times when I go to turn it on, what should I do?
And when i connect it with charger and press power button the red led turn on for a couple of minutes ..
please give me any solution it is not recognised by pc also..
any help
Have you tried this?
power & volume up (hold it for 5-7 seconds) = will restart the phone
There is another "XPERIA Z not charging" thread, where I asked my question, but it was deleted from there (maybe some admin suspected without reading that these were similar post, or I need to start my own thread to the same problem? Please drop me a PM in this matter, if this post will be also deleted
So, I have turned off the stamina mode on my Xperia Z, because while the phone and the softwares woke up, they did funny things.
Because of that of course my battery went flat.
Now if I plug it into a charger, literally nothing happens. The red LED does not turn on, there is no current can be measured, power+volume up does not work (power + volume down neiter).
Does anyone any idea, what should I do to be able to use the phone again?
I also had the same problem. Yesterday i tried to service center and they told me that the battery does not run properly.
I suggest to replace the battery, if the battery has been replaced and still not turn on maybe the ic or charging port is broken
Replace battery...
Unfortunately it is not so easy
Whatever, it worth to try, because it does not matter why I can't use the phone: dead battery, or I wreck it totally apart
Thanks anyway.
I left the phone somewhere for several days while I checked some battery prise, etc.
Now I plugged it into a charger, because why not?
It now charging, and I even can turn it on.
Wow O_O
Hopefully, it will work for a while without scaring me again like that
