Hello guys,
I am in need of some help with my Z1. I am unable to receive group messages and cannot send nor recieve picture messages.
I have tried downloading internet settings and also mannually entering "APN settings" listed below with no luck. Please help!
Apn:fast.t-mobile.com
Proxy:216.155.165.050
Port:8080 skip the next three then,
MMSC:http//:mms.msg.eng.t-mobile.com/mms/wapenc
MMS port:8080
MCC:310
MNC:260
APN type: default,supl,admin,dun,mms
APN protocol:IPv4
APN roaming protocol:IPv4
Save that as the first apn then create a New APN
APN:epc.tmobile.com skip the rest untill
MCC:310
MNC:260
APN protocol:IPv4
save these settings and ensure to have selecedt the first Apn on the Apn list (which should be fast.t-Mobile.com)
Turn the phone off for about 5min and then back on and you will be good to go. The very first MMS will take more than usual.
Good Luck!
Solved! Go to Solution.
Go to the APN settings and make sure that under "bearer" its unspecified and not LTE
Simple questions
1. Do you have a data plan?
2. How old is your SIM card?
3. Try settings > more > internet settings
hey uliwooly thanks for the quick reply!
1. yes i have a data plan
2. i believe 2+ years? (this could be the culprit?)
3. tried it, doesnt work
I used this same sim in my s4 about a month ago and it was able to receive group messages with no issues.
I've seen that on myriad occasions that either
1. The SIM card its too old
or
2. An antivirus or taskiller its acting up
hmm, it would have to be the sim card then because the phone has been doing this since day 1 before i even downloaded any apps.
the sim is about 2 years old but i've only activated and started using it a few months ago. QQ
Its always wise to re-install the latest update, it will smooth things out
Bridge (for Mac)
Alternatives on How to backup Xperias
i was toying with the network operators and i switched it to t-mobile 3g instead of the LTE and i was able to send/receive pictures along with receive group texts... but it automatically switched back to LTE logo up top and doesnt work anymore
Is your LTE connection stable?
thanks guys, i think its all good
