Xperia Z, ZR, ZL 4.3 Update Bugs
The purpose of this thread is to list any bugs or issues with the new update, please post a brief description of the issue.
Thanks. If you don't mind,can you show me how to take a screenshot?
simultaneosly press volume down and power key for screen shot, and other method is right to home button is small appsbutton or its like task manager there in bottiom you will find capture screen...
I seem to have found another bug. When turning Low Battery Mode on, it deactivates everything (Wi-Fi, Bluetooth), except Mobile Data. I've tried restarting the phone multiple times and it still isn't overwriting it. Have any of you encountered this as well?
When I remove any application from my phone, I do not like to look at offset label with the name of the application.
I also have problem with the wifi (doesnt work) when i have my smartwatch connected.
is sony aware of that bug??
Have you all re-installed 4.3?
got same about bar issue it sems title has jumped out of it's place 😕 sems to be something sony forgot to fix before release 😕
low battery mode is supposto deactivate most of the stuff thats why but you can go into it's settings and select what it shall or shall not deactivate.
ops sorry for double post 😕
updated!!!
faced battery bug 65 to 20% straight
but backing up apps now n will do a clean repair .. :smileysmileythumbsup:
Hello.
Video sound poor..., stabilizer have bugs. I'm sad.
