phone has been frozen for over 2 hours, tried to reset using the side off button but no luck, really need it for work and its only 3 weeks old, help!!
Solved! Go to Solution.
Press power button+volume up at the same time until the phone vibrates 3 times.Turn it on.
I have tried to do this 3-4 times today but still the screen is not responding. Is there anything else I can do.
I am travelling now and completely out of contact without the phone.
Thank you, this worked for me :smileysmileythumbsup: The screen was froze but i was still able to ring my phone so had spend hours ringing it trying to make the battery die haha. Decided to google and thank God found this help here!
Thank you so much, my phone was frozen for hours, I tried various things before Googling it. Held the power button and volume up button till it viabrated 3 times, then turned it on. It worked!!
Thanks so much, this worked on my frozen Z3 so great that your advice continues to help!!
Thanks, only vibrated once but worked a treat.
Hi my screen was frozen, took your advice and bingo it worked. Thank you
I just created an acount so that I could thank the Poster who offered the solution. It worked for my Z1 on the first attemt.
Thanks!
