Since I installed the last update people have been saying how poor the call quality is at their end.
To test it was the phone and not the network I put my sim in my iPhone 5s and used that for a week and had no complaints.
I ran the repair utility and then put my sim back in the Xperia Z2 to test it out. Upon inserting the Sim, the phone restarts but never detects that there is a sim in the handset. If i remove it, it says sim removed, restarting etc but never detects that the sim is in the phone.
The Sim is fine as it is back in theiPhone 5s and working. I had to use an adapter for the sim and i'm starting to think it may have damaged the inside of the sim tray.
Any one had any similar problems?
Hi, that is really interesting as to be honest I can't believe that I actually did miss off the house number. My main concern is I still haven't received it back. They still can't give me an update so I am just waiting in Limbo.
Funny thing is I have just recevied an email asking me to take a survey on how I feel my repair has been handled! I'll have a field day with that.
That is bad, the least they could do is offer you a replacement at this point.
I know, I am so annoyed right now. Just went back on the My Support to request another update. See the latest installment.
You have now been connected to an agent.
Scott: Hi david, thank you for contacting Sony Xperia UK Chat Support. My name is Scott, please could I take your full name and email address?
David James: David James
Scott: Thank you for providing me with this information, Please could you confirm which model of phone you have and which network it is on?
David James: Xperia z2 - vodafone
Scott: Thank you, how can I help you today?
David James: Can you please tell me the status of the following
Order number: 1-1680854782
Scott: I will need to look into this for you. Do you mind holding for a few moments?
David James: no problem
Scott: Thanks
Scott: JW094328146GB
Scott: Here id your Royal Mail tracking Reference.
Scott: It looks as though it is going to be sent out to you soon.
David James:
Status: Returned to sender
We were unable to deliver item JW094328146GB on the 2014-09-09 as it was not possible to identify the delivery address. We returned the item to sender on the 2014-09-09.
David James: That was 15 days ago
Scott: I will need to escalate this in order for this to be investigated further. Please could I take a telephone number for you to be contacted on?
Scott: And your correct address please.
David James: This has all been given to you in previous chat logs. It has been escalated 3 times now, I have also been told that a manager will contact me. However no one has. I gave you the correct address 15 days ago
David James: Read the additional chat logs that have been attached to my account
Scott: I am sorry about this, I will look for an update now.
David James: Thankyou
Scott: Thanks
Scott: I am sorry but we will send out another request today as we have had no response.
David James: That is the standard answer the Support team keep giving me. I was told this was escalated and they had 3-5 days to respond. That started on the 12th September. Nothing happened
Scott: I am sorry but we have had no response from our repair center.
David James: Emailing them again will not work. Please send me a new phone
Scott: Unfortunately we would not be able to do this.
David James: what can you do?
Scott: We need a response from our repair center and once we get this we can get your handset sent out to you.
Scott: I have requested our Escalations department to contact our repair center again.
David James: they are not replying and havent done in 2 weeks
David James: This does not work
David James: The process is failing, and as a customer Sony is failing me
Scott: i am sorry you feel this way
David James: Do you not see that Sony is failing me as a customer?
Scott: I understand it has not been the best service.
David James: The repair centre has had my phone for 23 days. They have failed to contact you to say where my phone is. This has been escalated approximately 4-5 times. You say you need to wait for a response. They DO NOT RESPOND
Scott: I do apologise for this.
David James: Its no good escalating to a team that do not respond
David James: How long am I as a customer of SONY expected to wait?
Scott: This is going to be dealt with as quick as possible.
David James: All of the 'My Support' operatives have said this, they escalate it, they get no response
David James: I have asked to speak to a manager, no one has called me
Scott: Unfortunately there is nothing further I can do, our escalations department are going to chase this again for you.
David James: Apparently you can't call the service centre only email.
David James: It does not work
David James: When should I contact you again to be told the same?
Scott: I would suggest contacting us again Friday if you hear nothing
David James: And what then, you will escalate it?
Scott: You should hear something by then.
David James: Can you not understand, I won't hear anything
David James: This is so bad.
Scott: We should have a response by then.
David James: What makes you think that?
Scott: As an email has been sent to our repair center whilst we have been speaking.
David James: Yes but Scott, several emails have been sent to the repair center. They do not respond!
David James: It has been escalated 4-5 times already!
Scott: I am sorry about this.
David James: Have you looked at all the previous chat history, that shows all the escalations from various 'My Supprt' operatives?
David James: This device cost me Approximately £600
Scott: I understand that David, we have sent information to our repair center requesting the information and this should be responded to at the latest Friday.
David James: It won't, it hasn't been responded to before.
David James: Ok, tell me. What will happen if they fail to respond again by Friday? What will you do, send them another email?
David James: That is all you can do, this needs to go higher. Higher than escalations
Scott: There is no higher than Escalations, if you call us on 03705 237 237 and nothing has been done on Friday then request a call back from a amanager.
David James: What is that number? That's just the My Support line again isnt it
Scott: This is our technical support line but they will be able to request a manager to call you.
David James: I have already done this. No one called me back
As expected. I was promised a call back from a manager today and it never came. Any advice on what I can do next?
Citizens Advice Bureau seems to be the only real option you have left, and maybe trading standards.
How long has it been away in total? Did you have to sign anything that stated how long it would take?
It has been 25 days now I think in total.
I only ask as we say that handsets can be away for up to 8 weeks. I work for a local provider in Jersey and we have to send the customers handset to the mainland for A-Novo to fix it, sometimes it gets held up in customs, but that's not an issue you'd have.
Either way, by now I'd have given you a replacement handset had you been one of my customers.
So I phoned the support again on Friday, spoke to a really apologetic guy on the phone. I explained I wasnt having a go at him personally just the company and how this case has been treated. He promised a call back from a manager and to make sure he kept upto date on the situation he said he would call me at 5pm on Friday to see if I did get a call from a manager or not.
I never recevied a call from a manager and I never received a call from him either at 5pm.
I am going to leave this now as my time alone chasing this round has probably outweighed the worth of the handset. They can keep it, if it does get returned it will be sold, very cheaply.
I follow Sony on Facebook and Twitter and will now spend my time more proactively by warning other consumers of the danger of buying products from this company.
Don't get me wrong the devices themselves are superb but the aftercare is atrocious.
It's a crime that they actually use the word 'care' as clearly no one does.
Thanks for the replies and suggestions. If I do get any other news on this I will be sure to let you know. However I feel that this case will just sit with escalations for evermore.
