by the repair of my phone (Xperia Z3+ E6553) i broke one part (resistor), neer of Flex Cable and i need the Value of these part.
All works fine after repair, but the auto display turn, do not work. In the Configuration ist it "on".
Can anyone help me?
The Support of SONY Mobile is extreme slow and i don't belive that Support would help me!!!
Thx. owsuisse
Solved! Go to Solution.
It's 15Kohm as measured with multimeter.
Do you have any advice for trouble shooting a suspected water damaged mainboard on my e6553? It seems to be hard bricked as opposed to soft bricked.
I am not an electrical engineer of any sought.
EDIT: I have posted a picture of the part below.
Have you fixed it yet?
Or you havent found the part yet.
