Xperia z3 keyboard lag
sygys22
Hey everyone,
Im having some very anoying keyboard lag on my Z3. I read some things about it on the internet and it seems to be caused by the down scaling of the CPU. in wich the keyoard isnt reacting like it should.
I made a video of it:
https://www.youtube.com/watch?v=uPIpjHitYyI&list=UUl3BUH8my0Z6KLFjzr-QkrA
Maybe there should be an option in the settings to manually set the CPU to not throttle down when using the keyboard. or give it some more power. Its pretty annoying the lag.
Sometimes its so slow it registers swypes instead of keypresses because of the delay.
I know the phone will hold 2 days of battery life and i can easily hit the 9 hours screen on time with 24 hours of standby with it. But i surely wouldnt mind one hour less screen on time if the keyboard would actually work...
Its a pain using the keyboard right now.
Rickard
Master
I just got information that this issue should be fixed in Xperia Keyboard 6.7.A.0.86
57 REPLIES 57
19667
ok try this and tell me what happend ok follow this
goto settings>>apps>>all>>keyboard>>clear data and restart your phone and watch how it works
Do not forget to give kudosKudos 2.JPGand to select the correct answer Solution.JPG
sygys22
No it isnt working at all. Even typing here gives a huge lag especially when using backspace or changing words. This has nothing to do with cache. Its a keyboard vs cpu problem. This great battery seems to come with a price... The cpu is obviously skrewed down while using the browser. And i dont like it.... So fix it! The z3 is useless this way. The longer this text is becoming the more lag im allready getting here now. This is insane... Only a few lines of text in a textbox is doing this... How the **bleep** did this even get through the test phase of the software. Try it yourself type this text im writing now in the chrome browser of your z3 type some more and press 5 times backspace fast after eachother. I bet you 100 dollars on it the z3 will only delete 2 characters. Its not my unit... The software is lagging
sygys22
Ps with stamina enabled its getting an awfull lot worse...
SergioPL1
I can recreate similar behaviour here on the forum using Z2 Tablet but can't figure out a root cause of it. It looks exactly as in your movie when hitting backspace and keyboard is looking for words to display. But this behaviour is related to Google Chrome. For me it doesn't happen in other apps like FB Messenger. I guess Google screwed up something within it's API that collides with Xperia Keyboard.
sygys22
Yeah well the z2 tablet isnt the z3... also tried this with the note 2 and the xoom tablet. But it seems the z3 has some over extended battery savings wich causes the cpu to not govern up when needed. It seems related to the swype function and the text prediction wich needs allot of computing power wich the kernel is not allowing to. This gives the insane lag in the keyboard. You can blame chrome... but this is the only device having the problems. So sony better fix the problem.
I can also tell you the lag is in long texts in facebook and whatsapp too. Its less of a problem wich thirdparty keyboards though. I use thumbkeyboard right now wich gives allot better experience then the stock keyboard.
I do keep wondering why manufacturers never seem to admit their mistakes and just freaking fix them instead of always blaming something else. Wanna know why people domt buy sony products.... start supporting your darn customers. And listen to them.
Im going a long way back in computers and handhelds i sure as hel know what im talking about. And im telling everyone. The keyboard on the z3 is broken.
Ps. The reason why longer texts are causing more lag, is because all words that are typed have secondary words of miss typed. And are all saved. Type a long text with a misspelled word in the beginning. Then at the end press the word. He will still remember what you typed. This is why long texts are more laggy... altough the z3 is more then powerfull enough the powersaving of the z3 is a pain on the keyboard...atleast let people choose to have a smooth experience or not.
sygys22
I allready regret buying this **bleep**ty device... i should have stayed with samsung and buy the note 4 now i have this pain in the as z3 for 2 years lagging ma as off everytime i typ some text...great! I
sincerely regret buying this device Slightly_frowning_Face i really hope the keyboard gets fixed.
Also the battery indicator is messed up. When it saying its full and get it of the charger it will drop 10% in less then 30 min use. Charge it for an hour longer after the device says its full and it will keep 100% the first 30 min of use. So its telling users its full too soon. And keeps charging after 100%
ashishsingh007
I didn't see the video but did you try custom keyboard? Like swiftkey or swype? Both are excellent keyboards. I prefer swype though. Try it and report back
sygys22
Swiftkey works allot  better indeed.  I also see hiccups in that keyboard thought. Especially when typing this here. The sounds of the key presses is sometimes strange too now when typing this like the sound is trying to keep up. I really don't know what's  wrong with the z3.  Even if there is a keyboard that actually works on this device then still should Sony fix their own one...
Johan
Master
It seems only to happen using Chrome but could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
