My z5 fell in water accidentally and now it is not switching ON . I kept it under the sun for a while then tried switching it ON. It just showed the Sony icon and got switched off again. After that it never stopped vibrating . Even the led lights are ON. I tried pressing the power button with volume + . It don't work.
Please help if somebody knows something about this
Hi!
I'm sorry to hear that. Normally, the phone should work perfectly well even after falling in water, assumimg that all the ports were properly closed.
If the problem still goes on, you should contact a sony service to have your device checked out.
Here's a link to help you with that: https://support.sonymobile.com/global-en/repair/
Have a great day!
