Xperia z5 premium problems
EduZanetti
Meu Xperia parou de funcionar a entrada do fone e junto a isso também parou de funcionar o viva voz  depois da atualização.  Reiniciei o aparelho é agora a vibração dele não está funcionando, o que faço?
Translation via Google translate:
My Xperia stopped working the phone's input and along with that also stopped the speakerphone after the update. Reboot the device is now the vibration of it is not working, what do I do?
profile.country.US.title
Qatrium
@EduZanetti
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup.
Follow the steps given in blue links, and keep us updated.
