Solved! Go to Solution.
Thank your for your feedback regarding the keyboard. I will pass this on internally.
Try the different keyboard layouts. One of them gives ample space between the space and the dot. to change the keyboard layout go to Settings > Language & Input > Xperia keyboard > Personalisation guide
I can see in the settings the option to disable the comma and full stop keys are there, when you disable and goto change the keyboard skin they are removed from the example but not from the actual keyboard.
Very annoying please assist
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
I am also having this problem with the Z3 I've looked up online if it was possable to remove the dot and extend the space bar but so far i have found nothing, if someone knows about one please tell me.
I have same problem on xz premium. Best phone i have had except the sony keybord is the most annannoy issue i have ever had.
