Z1 Battery and Vibration Motor Replacement in Canada
reventon_703
Hi, I would like to get a battery replacement for my Xperia Z1 (C6906) (bought around Sept 2013 from Rogers). The battery fails to hold charge and would automatically shutdown (jump from 100% to 0%) whenever the phone is not plugged in. This problem persisted since April 2016 but it has gotten unusable lately. I cannot keep my phone on long enough to even make a call. I have already performed a factory reset, updated to the latest firmware and calibrated the battery but the problem remains.
In addition, there is a also a vibration motor defect (had this problem ever since I bought the phone) resulting in a "squeaking" sound whenever the phone vibrates. If possible, I would like to fix this with the battery problem altogether.
To whom should I contact? Is there an actual email address I can contact Sony with?
(I have tried contacting Sony Canada through http://support.sonymobile.com/ca-en/contactUs/ but Start Chat leads to a 400 Bad Request Error while the Email Us option remains stuck upon clicking Send.  Same results with different browsers.)
5 REPLIES 5
profile.country.PH.title
MarlonUk1
have you tried calling customer support in your country?
or if you brought the device with your network maybe they can replace it.
CameronT
Champion
Hi @reventon_703,
I am not sure what may be wrong with the chat and email functionality. I recommend you give them a call.
I have found the contact information for Sony Canada here:
Monday to Sunday : 08:00 - 23:00 EST
‎+1 1 866 766 9374 (Toll Free)
reventon_703
Thanks for the quick reply! I have filed a case for repair.
Just another question, I was told to remove all accessories before shipping the phone to the repair centre, in particular:
  • Battery cover (if removable)
  • Battery (if removable)
  • SIM card/SIM card adapters/memory stick or microSD card (if applicable)
  • Removable front faceplates (if  applicable - refer to User Guide)
  • Wrist bands/straps/belt hooks (if applicable)
Does this apply to screen protector as well? I have 2 tempered glass screen protector attached (one on the front, one on the back) and I am afraid it would be quite difficult to remove (the adhesion is strong).  Should I attempt to remove them regardless? Or just the back? (as I understand a battery replacement for the Z1 would require prying around the back cover)
CameronT
Champion
@reventon_703,
It depends entirely on the local repair centre. In some cases it may not be possible to salvage the screen protector. I recommend you ask your local support team if this would be necessary.
ianderrick1818
I have also met same problem. My phone is not work last year. And I just bought a vibration motor from
Baolong.Then the phone was workable again.
