Couple of weeks ago my sony z3 compact screen turned to have white washed screen as below pictures.
I tried to switch off/on the phone and adjust the "white balance" from display setting already and none of them worked.
Is there any setting option i pressed accidentally?
Solved! Go to Solution.
It looks like the setting "Colour inversion" is activated via Settings > Accessibility > Colour inversion, could you check this?
Hi Hampus.
It is sorted now. Thanks for the quick response
Glad to hear that, you're welcome!
