Solved! Go to Solution.
Have you rooted your device or unocked the bootloader?
If you have 4.4.4 on your Z3 PlayStation Mobile its no longer supported by Sony
Are you trying to play PSMobile games or are you trying to play PS4 games? if the later you will need the PS app and Remote Play (of course a PS4)
It's not going to happen
