hi all
i just got my z5 couple days ago and i already have a problem with my phone
when im about to type a msg and i press a letter (lets say i press S one time) the phone will register it like this sssssssssssssssss
and it wont stop ... if i use facebook i cant scroll down because everytime i try it will enter every single post or picture
i also have a small recording of some of my problems where i have to press many times before the phone wants to do something
https://www.youtube.com/watch?v=ddfC30WEm2E&feature=youtu.be
NEW VIDEO https://www.youtube.com/watch?v=jusF9pr8oX4
if i lock the phone and open again the problem goes away for some time and it happens again if i use it for a bit
i did reset/reinstall the phone .. same problem
Solved! Go to Solution.
Yes i have the same problem. Sony take notice!
Same thing here, the device is barely useable. Sony, this is very serious. You should immediately stop selling this model until this is sorted out!!
EDIT: Mine is white
I have the same problem as well, but it doesn't happen as frequently as it sounds like it does for you guys... Hoping an update can fix it, do you think that is to much to hope for?
The phone works if your not doing anything with it. But when you start to use facebook or chrome or any other app the screen just stops working.
So it's pretty unusable. Software or hardware failure??
Could you post the softwares buildnumber? So people can find out its firmware related.
I have also 32.0.A.4.11 mine is white. If that has something to do with it.
