Hello,
I don't know if anyone can help. My Z5 doesn't seem to hold charge at all anymore, and hasn't for sometime.
I leave it to charge all night and unplug at 7:30am, it is dying or close to death by 9pm, this is far less than the battery should be lasting for.
Do I just need to replace the battery or is there something else I can do? I have tried the battery saver options but this doesn't work either and the battery should be lasting much longer on standard settings anyway.
Andrew
hi
do you use Facebook lots? and also have many continuous sync services active? in particular... google stuff... like super annoying maps notifications and photo uploading and wifi messaging services?
Dear Friend
yes the very first thing you have to change is battery if it is still same it means there is IC problem which can be repaired by local technician locally.
you can identify weather it is a battery problem or ic problem, if the phone is becoming very hot may be it IC
Hope it works
Tahir Khan
Malaysia
