Z5C problem
Flokic
Z5C problem
Hello,
I have got my z5 c since thé Day one but with Android nougat i can cooking eggs behind the phone.  I can had 47,9" degré celsiuis.
Anyone has got answer for this problem
Tags (1)
Uliwooly
@Flokic
if you use the above search bar you could find other threads on the same question, you could repair the phone with XC but keep in mind that the more apps that you have running the hotter it will get.
Aliunique
Also it depends on your situation
For example when the room is hot or warm it will effect on your phone too
And when you are in cold places your phone will become colder
