A7 app-c crop sensor
Briopad
Sorry if this has been covered but I can’t find an answer
I wanted to set up a custom button on my A7 for the crop sensor but it doesn’t appear on the menu! It’s a bit of a pain going into the main menu each time.
Am I missing something or is it not possible?
many thanks
Brian
13 REPLIES 13
Hi Brian,
Hopefully a community member can help with this.
Best wishes,
M
roydale62
On my A7R4 and A9 it is custom key set in the menu and then scroll to the button you wish to use. Select it and then select APS-C S35/FULL FRAME SELECT click ok
that should do it
hope this helps
Roy
Joe_Dohn
Specialist
I absolutely agree. Here's a link from Sony's Help Guide for he exact steps as well: https://helpguide.sony.net/gbmig/44840601/v1/eng/contents/TP0000226608.html?search=custom
Briopad
Thanks John for the reply, but on the A7 it does not appear as one of the options to choose it seems. That’s why I wondered if it’s somewhere else
I’ve  just bought a 70-200 EF Sony lens and this function would be brilliant but it’s just not there.
have checked on firmware of the camera and it’s up to date. Odd
cheers
Brian
Briopad
Thanks for replying Roy
I’m getting the feeling the A7 is too old to have this function on the custom buttons although it seems to have lots of others I use.
I would have hoped they would have updated the firmware for the A7
cheers Brian
Win_88
Specialist
Hi Briopad,
For the sake of keeping things up to date, have you made sure the firmware is updated?
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3
Win_88
Briopad
Hi thanks for replying. Yes checked the firmware and all up to date. Just convinced the A7 doesn’t support this custom option even though it’s on the main menu
roydale62
Hi
Why not add it to the fn menu much quicker
Roy
Briopad
Thanks again Roy and an excellent suggestion. The problem is it doesn’t appear as an option their either. It’s only on the main menu. I feel a bit annoyed that as a newcomer to Sony I bought the camera 18 months but it seems it’s out of date with no updated firmware now available. Still a brilliant camera though. Thanks. Brian
