A7R III update 1.10 impossible Mac OS 10.13.4
photuris
Hello all,
after repeated attempts and increasing frustration I have had no luck whatsoever trying to iupdate the firmware
I have followed the instructions to the letter so it's not me
perhaps OS 10.13.4 not compatible?
anybody had similar problems?
advice welcomed
thanks
photuris
solved! the problem was the Security & Privacy in 10.13.4 System Prefs would not allow the installation of the driverloader_1013
- solution was to manually install the kext into MacHD>Library>Extensions
the update then ran without a hitch..
6 REPLIES 6
photuris
batee5
Specialist
Hi photuris,
Thank you a lot for sharing this solution with us!
Regards,
Batee5
pan2000z
Hi photuris
I've spent ages on trying update. Please can you advise me how to manually install the kext into MacHD>Library>Extensions. I would be most grateful.
Thanks Alan
BRUCEWANGPHOTOGRAPHY
me too! I'd like to know. Bruce
photuris
OK this is what I did as a workaround when the DL110_1712a would not install because Security & Privacy in 10.13.4 would not allow it - but I can't guarantee it will work for anyone eklse
1 double click to open the download disk image having dragged from downloads to the desktop
2 'right' click or 2-finger click to open package contents
3 Open Package Contents>Contents>Resources
at the bottom of the list is the kext called SONYDeviceType01.kext
4 drag this to your Library extensions folder and the Updater shoud run
good luck
pan2000z
Hi photuris
Thank you so much for your clear instructions which are very much appreciated. I'm travelling at the moment and I will be updating tomorrow.
Thank you Alan
