A7R III update 1.10 impossible Mac OS 10.14
C.C.E.B
It seems impossible to update firmware using Mac OS10.14 Mojave.  Any ideas?
Many thanks.
Chris
NigelPP
I have now got this to work. Once the camera is connected successfully by running the update setting tool, look in the Resource folder that is part of the download and run the System Software Updater App that you will find there. I'm now successfully updated to V2.0. Make sure your battery is fully charged as it takes a while.
profile.country.FI.title
launonen
if not working cto usb caple 1st and there is 2.00 all ready on-line
NigelPP
Me too. Updater (to 2.00) in not working in OSX 10.14.
NigelPP
