A7rii battery
uganda4
A7rii battery
Does anyone know if the A7riii battery is compatible with the A7rii?
I'm hoping to use the camera for longer between recharging...
Tags (3)
IamNic
Hello @uganda4,
according to the spec-sheet, the A7Rm3 uses the NP-FZ100 battery, which according to the compatibility-chart is not compatible with the A7Rm2.
- Nic
uganda4
Thankyou
