Can someone help with 200-600mm lens
Mconstant
Where is there  detailed instruction how to use this lens please?
7 REPLIES 7
HI there,
You can find what you need here.
Hope that helps.
Best wishes,
M
Mconstant
What help? Awful customer service
Sent from my iPhone
Pascale_F
Moderator
Hi Mconstant,
Welcome to the Community.
If the instructions in that link don't help you, you can always contact Sony Support.
Thanks,
Pascale
morphfromthenorth
It's not awful customer service.
You asked for detailed help and someone sent you a link to the instruction manual which does contain detailed information. If you need some help on a specific area, then ask a more specific question.
Regards
Steve
Mconstant
Pleasecan someone help with how I use the lens on a Sony 6300. How /what settings so I can focus on what I wish to focus . a bird 200mm or say 600 mm away?
There are no videos o can find
Only how to look after lens
Sent from my iPhone
ChrisLathamPhoto
Point it at the subject, compose and press the shutter button.  Be more specific on what your problem is if you want more than this.
madge115
hello and wellcome to the community   it sounds like you are a complete novice i may be wrong but  but hope this helps with the absence of camera shops being open where you can be shown   i suggest you put camera in auto  and let the camera do the rest all you need to do is adjust the distance of subject with lense hope this helps for now  any camera shop can guide you once they open again   good luck   madge 115
