Cannot update the LA-EA1 with a Nex5n
DouglasGrillo
Hi Friends;
I need information about firmware update of the LA-EA1 with the Nex5n, smeaone has done this procedure? i cannot make it work, the firmware update software do not recognize the Nex5n.
My LA-EA1 is version 0.1 and the latest is 0.2 but i don´t know if the update must be done just to work with a prior models to the 5n Nex camera.
I don´t have any Alpha lens right now, i don´t know if this can be a problem for the updater?
Thanks in advance.
Mick2011
Hi Douglas, welcome to the Sony Forums :slight_smile:
According to the update web page, you need to have an alpha lens attached to perform the operation.
Mick
Mick2011
Mick
DouglasGrillo
No way!
I´ve tried with a lens (tamron) try in Mac and PC and still does not recognize the Nex 5n, both version of the updater the Nex 5/3/C3 and the Nex VG10, and nothing.
profile.country.de_DE.title
cmosse
for Nex-5n no update is required to use the LA-EA1
