Changing the size of the focus box in live view
MisterSonya7riii
Hi, Just a quick question, does anybody know if I can change the size of the green focus box on the Live view screen, I have a a7riii.
jumpsuit
Hi @MisterSonya7riii
You would have to change the size of the focus area in the settings.
Have a look at these two videos for some focus help.
Hope this helps :slight_smile:
MisterSonya7riii
Not really, as it is not the different focus modes I am on about. It is the actual focus box that I want to change, when using live view and I pick a focus point on the screen with touch, the focus box goes green, it is that box I want smaller.
jumpsuit
Hi again
You can't 'squeeze' the box smaller with your fingers on the camera screen, but you can alter the focus area
size in the fn menu.
Read this
Cheers :slight_smile:
