Help please :) - A7iii / Movie / Manual / I can't change the aperture manually???
Hi - I can't figure this out and hope someone can help. I can't change the aperture in manual mode.
Do you know why?
Sony A7iii
Mode Dial = Movie
Exposure Mode = Manual
I have the front and back dials set to AV/TV.
I can change the shutter speed but not the aperture. Any idea why? Can you help?
Thanks - Amy
Doh!
I think I have just found that I had to click the lens aperture ring over to an "A" setting.
I had assumed the "A" stood for automatic - which I didn't want - but in fact I can now manually change the aperture from the camera dial so my problem is solved.
Amy :slight_smile:
Doh!
Amy :slight_smile:
