Pop Up Flash an Irritant when Using Wireless Flash....Please Help !!
theshinyrock
First timer by the way, so go easy on me.......
I have purchased after a long an inspiring partnership with an A100,  of which is now a proud "back up".....a Alpha A580.
I was hoping, and still do hold out for some help....that the Wireless Flash feature would work without the pop up flash destroying my picture.
However i find even now, the A580 fires the pop up flash when using my HVL-F42AM wirelessly and completely destroys the effect of having light from a different angle !
Can u help me with my frustration please, and suggest a way, other than a piece of card or my hand to stop the pop up flash firing....?
Thanks.
gimp69
theshinyrock
Thanks gimp69,  i'l search for a cable !
sligophotog
you should be able to set the ratio so that the onboard flash does not contribute to exposure, are you using ttl or manual flash settings?
