problems with continous autofocus on Sony Alpha 7
profile.country.RO.title
Vandraattila
I have bought a Sony Alpha 7, with an E-Mount 50mm F1.8 OSS Lens and a Sony E-Mount 70-300mm F4.5-5.6 Telephoto Zoom Lens.
At the beginning I have used them on static themes. It was ok, quick autofocus for both lenses. Big was my surprise, and a bad one, when I tried tu use the camera for mobile subjects. with continous AF (AF-c) It was focusing very very slowly, an most of mz photos were blurred.
It is a problem which needs service, or a general problem a week point of the camera type? the camera has the newest version, 3.2
I am waiting your suggestions advices.
Anticipated thanks
Attila
12 REPLIES 12
EdwinaU
Moderator
Hi Vandraattila,
We will look into this and update you when we have more information. Meanwhile, some other members may have some tips or advice for you.
Best wishes,
Ed
Win_88
Specialist
Hey there,
Have you tried resetting the camera to factory settings? You can find the steps here.
Win_88
Vandraattila
I had problems with my S18-50 lens, (solved) and in the service it was reset,
Win_88
Specialist
Are you saying that the S18-50 isn't having the auto focus issue anymore? You didn't mention anything about service so I'm a bit confused *_*
If there was a service event, which parts were inspected? the body of the camera or the lenses? (maybe both?)
Win_88
Vandraattila
The 1,8-50 had a difdeerent problem, so I did not mention it, however it was an AF problem too. on F1,8-8 it worked well, but at 9 or more was continously focusing, it was impossible to focus on any object. It were changed in the service some parts of the obiectiv, and the camera was resofted.
I did not try to use the fix 50mm lens for sports. It is not suited for. Except the case you want to see the birds on the photo with microscope :slight_smile:
maybe it worth a try with cars? Let me try today, A little bit later, because my camera is in the bedroom, and it is early morning in Australia.
Vandraattila
The 1,8-50 had a different problem, so I did not mention it, however it was an AF problem too. on F1,8-8 it worked well, but at 9 or more was continously focusing, it was impossible to focus on any object. It were changed in the service some parts of the obiectiv, and the camera was resofted.
Vandraattila
@Win_88 wrote:
Win_88
Attila
Win_88
Specialist
Hi @Vandraattila
It will be interesting to see the result of that test. Since the body of the camera is the common factor here, I think you should try resetting it if that hadn't done that in a while too.
Win_88
Vandraattila
@Win_88 wrote:
Hi @Vandraattila
I have made some experiments today. The AF-c is OK with the 50mm lens, and also with the 70-300 if I use it at 70 mm. If I use it with 300 mm trying to make several photos of a departing car, the auto focus is ok, then  "lost" and and Ok again after a while.
conclusion : The real problem is, that using this lens for subiects being far from me, AF becomes very slow. For subiects at 3-4 m it is OK. it is not an AF-c problem, onlz of speed of focusing at distant subiects.
Attila
Win_88
