Sony ILCE-6400L plug
jimmysmithson
Can anyone find a picture of the actual plug for this camera please.
Reason I am asking is I have 2 one for this camera and one for my old DSC-HX9V but can't remember which one is for each camera.
jumpsuit
6 REPLIES 6
IamNic
Hello @jimmysmithson,
if I am not mistaken both cameras use the same cable type for data transfer, so it doesn't matter which cable you use.
- Nic
jimmysmithson
Hi
Not the USB part mate the actual transformer part with the mains plug.
jumpsuit
Hi @jimmysmithson
Here you go :slight_smile:
jimmysmithson
Nice one jumpsuit I was just going to post pictures of both but that's just helped me a lot.
This is the other one
20200216-004410
jumpsuit
Hi @jimmysmithson
you're welcome :slight_smile:
IamNic
just use any USB plug with a 5V 1.5Amp output. Any will do - literally.
You can also charge the camera on your computers USB port or a phone charger.
- Nic
