Bluetooth headphones stopped working /tv sound still on
Mickytaker
My 49xf7596 did an update last week, my Bluetooth headphones connect and sound continued to come from the TV tried uninstall & different headphones also volume graphics do not show when headphones connected. the volume on the headphones is not effected by the volume control.
Any ideas
Micky
Tags (1)
4 REPLIES 4
rooobb
Your TV do not support natively Bluetooth headphones, so how did you connect them before the update ? Using a third party app?
Mickytaker
Yes via a 3rd party app. Worked for about 2-3 years until now
rooobb
So you should check with the third party developer or try a new one
Mickytaker
Tried a different app, because the old one was removed as not required after pairing
