I Player on XR-77A80J
Derek-.973
I keep getting logged out of I Player
I've updated tv
Factory reset and updated
Cleared the cache
Cannot uninstall and reinstall I Player App
What can I try next
Piscie
Community Team
Hey @Derek-.973 which software version is currently installed? and have you cleared the TV's cached data or the cached data for the app only? You can clear the TV's cached by pressing ( settings > system > storage - > cached data ) I'd also suggest testing your TV with different internet source and check again.
Derek-.973
I have tried everything
Factory reset
Latest software
Cleared TV cache
Cleared Iplayer Data and Cache
Cleared Youview Data and Cache
Cannot have Iplayer as a stand alone App  (have to enable Youview)
I GIVE UP
YOUVIEW IS RUBBISH AND BY ASSOCIATION IS IPLAYER
IPLAYER SHOULD BE A STAND ALONE APP
THANKS FOR YOUR HELP
PS I CAN CAST IPLAYER FROM MY £300 ANDROID PHONE
BUT NOT GET IT ON MY £3500 SONY TV
HannahEd01
Community Team
Hey Derek-.973, the issue that you're experiencing is a bit odd to be from the TV itself. Try checking with BBC.
