Bluetooth connection
Yarg1234
Hi trying to connect my dcr-pc120e to bluetooth but asks for connection key,what and where is the key no I should use thanks..
Mick2011
Hi Yarg, welcome to the Sony forums :slight_smile:
Bluetooth hosts usually need to authenticate a peripheral device (camera) in order that it can share the network. This usually happens by way of a pass key transmitted to the peripheral device from the host device (for example, your PC) which you read from the PC to and enter into the field provided on the camera screen.
This all assumes the camera has been 'discovered' by the host and prompted you with a key. Has this happened in your case?
Mick
