Lost software for DCR-SR37E
Kadders
Following a hard drive failure I need to re install the software for Handycam DCR-SR37E but cannot find the CD. Any help you can give gratefully received as I need to burn to cd my sons London Marathon run on Sunday!
Mick2011
Hi Kadders, welcome to the Sony Forums :slight_smile:
You should be able to manage without the CD.
The Sony site lists this camera as compatible with PlayMemories Home or you could use something like Windows Movie Maker; both are free downloads and will let you edit and export your movie as normal.
Mick
Mick2011
Mick
