DCR SX30E SONY HANDYCAM. CAN I REMOVE "WRITE PROTECTION"?
profile.country.el_GR.title
ntonas1962
Hello everybody. I have a DCR SX30E SONY HANDYCAM. I want to remove the "write protection" from the internal memory or/and the memory card. Does anybody know if this is possible and if yes, tell me the way to do it? Please help. Thanks in advance. Antony Fot
Message was edited by: ntonas1962
Mick2011
Hi Antony :slight_smile:
You should be able to move a slider on the memory card to 'unlock' it and remove write protection.
Mick
Mick2011
Mick
