Distored moving image with hdr handycam
profile.country.en_AU.title
jamgeary
I have had this camera for a month or so now but only just started playing around with it. i have done some day time shots and also some filming at home. Now when i first used the cam it was in the aeroplane (in a open cockpit tigermoth ... very bright day) and i though the issue was because the plane vibrated. but i have tested it again at home (camera steady, but hand moving drawing images) and getting same issue. So 2 different filming sessions under 2 different lighting situations.
basicly i get horrizonal line whenever something moves. it seems to be worse if something moves faster. appears very distorted.
The camera is a Sony HDR-XR260
I'm filming on settings;
record mode: ''highest quality [FX]''
frame rate: 50i
hd/sd setting: HD
x.v.color ON
image size; 16:9
recording to camera HDD
white balance: auto
spot meter/fcs: auto
spot meter: auto
spot focus: auto
exposure: auto
focus: auto
low lux: on
fader: off
steady shot: active
auto backlight: on
one thing i will note is that the first time i used it in the aeroplane it kept having issues writing to the hdd. had some kind of error on screen about 'writing to hdd'. cant remember what it said tbh. it was a bumpy ride so i didnt think much of it at the time.
image attached. 2 pictures here. one is from the tigermoth. Look at the red frame of the plane.
second image is my drawing. not the best lighting. but u can see the pencil is in focus and my moving hand has the lines on it.
blaireau_photo
Hello Jamgeary - Welcome to the Sony Forums :slight_smile:
I saw the question that you posted on an existing thread, and I have provided some further information there:
https://www.sony.co.uk/discussions/message/1300809#1300809
Having now read your post above, I would strongly recommend finding out if a repair is required as you have not had the camera for very long - any serious faults should be covered by the warranty.
Thanks,
Simon
