Help Please with hdr-cx240e video transfer to laptop
UserNameNotAvailable
Hi, complete technophobe here so apologies for limited understanding!
Have been unable to transfer video from Handy Cam HDR-CX240E to the laptop via PlayMemories Home.  Followed an online guide that took me through checking the settings on the camcorder - seemed fine - and then through reinstalling PlayMemories Home - followed instructions and seemed okay.
When trying to import files still getting a message asking me to turn on the camera.  Camera is on and plugged in - bought a new cable in case that was the problem.  Still getting the same message saying to turn on the camera - again, it's on and plugged in.
Any ideas as to whether I'm doing something wrong or if there are other things I can try doing to sort the problem out?  Many thanks :slight_smile:
IamNic
Hey @Sean_Mc,
the HDR-CX240E is a digital camcorder which uses SD-cards as medium, so your tip is unfortunately not helpful.
Hello @UserNameNotAvailable,
What does your camcorders screen show you as soon as you plug the camcorder into your computer?
Did you connect the camcorder via the USB-cable hidden inside the hand strap?
You can easily pull it out of there and connect it to your computer.
- Nic
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Please see more details on how to transfer video from a Digital8 or MiniDV camcorder to a computer running a Windows operating system here
Hope this helps.
Best wishes,
Sean Mc
IamNic
Hey @Sean_Mc,
- Nic
Hello Sean and Nic, thank you both for your responses and information.
I am very embarassed at how thick I am!  I had not plugged the hidden cable into the laptop; I thought that was just for charging it up :confused: I had another cable which I thought was what I was supposed to use but that turned out to be the one that you connect to the telly :slight_smile:  So I bought a mulit purpose one thinking I might have chucked out the one I needed when we moved house a little while ago.  And now I discover that the one I was supposed to be using was there all the time :slight_smile:  Lol, what a wally.  Anyway, yes, I have now plugged the right cable in and everything is working perfectly.  I'm very glad the forum is anonymous so that no-one knows how daft I am :slight_smile:  Lol, thank you both again and hopefully I won't be this daft again in future :slight_smile:
IamNic
no worries, sometimes one is stuck or can't see what is obvious to others - there is no shame in that. :cool:
- Nic
